Originally posted by GDRoth what steps should I take immediately upon arrival so I can send back if necessary?
Surely someone can provide better guidance than me, but here is my simple approach:
I take pictures of a brick wall (the side of my house). I use the same section always, and adjust the distance so the area photographed is roughly the same. I position beer bottles (I found that they work better than soda cans
) in the corners, and on an electric box in the middle. The labels work well for evaluating contrast and resolution.
A tripod is must, and the camera has to be
absolutely level, and
perpendicular to the brick wall. Especially with UWA lenses the latter is critical. I then take pictures at ISO 100, and at a couple of different appertures, and (if zoom) focal lengths, using a remote release, and mirror locking. Note you should do any focus adjustments first.
I now have a "library" of these pictures, so I can compare results. The Tamron, for example, is weaker in the middle than the extremes.
Not very scientific, but when you compare your results to online tests, it gives you (IMO) a better appreciation for those "numbers" mean
Be careful though. When I first tested my DA* 16-50mm I thought I had gotten a bad copy, but it turned out I had not aligned the camera prefectly, causing one side to look soft (I have a hard time distinguishing between out of focus, and just soft - maybe someone could enlighten me on how to distinguish???)
Like I said - others may have a more comprehensive/accurate method.
